2 wd truck rims
yes the lug pattern is the same, but i don't think the center hole is big enough to go over the frt hubs of a 4x4
That is what I had heard as well, wanted to make sure with others before I bought them. Thanks
Diitto--
Yep--the lug pattern is the same,but the centers might be too small to fit over 4wd hubs--also,drum brake wheels will rub the calipers if you use them on disc brake front ends--I ran some OEM 16.5" drum brake style 4x4 6 luggers with 1/4" wheel spacers on my 72 K5 with no troubles...but there IS less threads holding the lugs on when you use wheel spacers..
I saw a K5 in the junkyard the other day,that had 14" 6 lug nissan rims on it,with the centers chopped out!--had 195/60/14's on it!--looked like skate wheels!...guess thats one easy way around those crappy 2.56 gears!..:eek1:
:crazy:
