Wanted 2 Wheel Drive Turbo 400 Transmission
Capt Ron
Lakewood Co
I'm needing a good used short shaft turbo 400 transmission. I'm a bit leery of buying used, especially off of C-list or FBMP. I figure CK5 guys can be trusted. Can pick up within a reasonable distance and headed to Vegas 4-17 so anything on the way/back would work out great. Thanks
Short shaft 2wd slip yoke?
I have a nice built one that is in my 70 c10 but I woul rather put a 700r4 instead. It hasn't been driven other than moved in the parking lot a couple of times.
What's it worth to you?
I might have someone going in that direction in a few weeks and could possibly drop off somewhere in Colorado for a convenience fee.
If you want we can take it to pm
have one in my garage with a tci master rebuild kit in it............
This is for the Mitchell motorhome. Yes, short shaft, slip yoke.
https://ck5.com/forums/threads/help...gmc-chassis-mt-motorhome.342620/#post-4153024
I dropped a sml blk in to get it mobile and transmission has no park, reverse or neutral. It wants to drive in all gears?
I'm trying to go low budget as this is for sale and if not sold will be parked in the backyard for a couple of years until I buy some property out of town/state.
It sounds like you guys both have some pretty good transmission's and probably worth more than I can justify spending right now. I'm trying to be all in for around $400.00 ish. I do have a lot of parts I could throw in with the cash if your needing anything?
I might be needing an np241 with vss
ya this trans built hold 1000 hp , think your looking for a more stock one
