2 York Compressors ($30 each / $50 Both)
B.N.Z.MTNS
Elevation 8,500’
Western Slope, CO (Elevation 8,500’)
I have 2 compressors for sale. One is a York with a tapered shaft, no pulley or clutch. The other looks very similar but has a Ford label on it, it does have the clutch/pulley on it. There are some brackets, an idler pulley and some rigid lines with them.
I've had them for about 3 years but have never run either of them, both shafts turn easily and there is some oil around the ports indicating that they were both oiled when used last.
I'm asking $30 a piece or $50 for both + shipping. I'll keep them on here for a few weeks before I list them on EBAY starting at $40 each.
If I remember right, I purchased these for $40 a piece. I was going to mount one on my rig for a compressor and my brother was going to use the other. However, my brother is selling his rig now and my plans have changed. Since I have AC and hydraulic assist now, I seem to be running out of space in my engine compartment and I do not want to add another belt driven accessory to the mix. I am thinking of building a power tank for my air purposes.
Pics were taken in my driveway last week and are the exact condition they will be shipped.
It appears that the website has a problem with the uploader and wont attach my pics...I'll try to attach some later.
These are not Yorks they are steel not aluminum
I have one of those and they are Ford
I know the one is a Ford and definitely heavier by a few pounds. The other IS a York as indicated by the tag in the picture. It seems lighter than the Ford model so I believe it is aluminum, but hard to tell without the clutch and mounting bracket etc.
Either way, they should pump air the same hopefully.
Adam, PM received and replied:thumb:
I forwarded the pm to Mr.Clean (nate) so once we bleed his brakes and clean the shop up he should pm you.
If he forgets just let me know and I shall yell at him :D
We shall take them. Weight dont matter :D
Except when you calculate shipping costs :doah:
These are still for sale as of today. After calculating shipping costs it turns out the deal wasn't so good for Mr. Clean...no worries.
For anyone interested in these, here is some additional info to help with your decision.
-They will ship from Montrose, CO 81401
-Weight on the York w/out the clutch/pulley is about 20 lbs.
-Weight on the Ford version is about 40 lbs with clutch assy.
-All other pieces and parts are less than 1 lb.
Shipping to Michigan was going to run $60 - $70 for both compressors.
If you are local or know somebody passing through, still a pretty good deal.
