shadowwalker_02
I remember reading a thread where ryoken said you need 10psi per 1000 rpm. I don't know if that was for a sbc or bbc? I searched but I couldn't find an answer. After starting the 468 and keeping it in between 2-3k rpm for cam break in I noticed while idling around 1100rpm or so the oil psi drops to 20. Between 2-3k rpm the oil psi is around 39-40. Is this normal for a bbc after a rebuild? I know I'm a bit paranoid with this motor but I want to make sure.
The other thing I noticed after shutting it off was the fact that the fuel in the fuel filter had alot of air bubbles coming up through the line. I know I don't have a return line on it so is this normal? I've never encountered a situation like this before.
I think after it cools down I'll run it for another 5-10 minutes and then hopefully I can maybe take it around the block. Assuming I can keep the headers and exhaust from melting crap and starting more fires. The S bends are allready turning a blueish color.
Being a homeowner is challenging at times. Not to mention a pet owner as well.
