Joe In Montana
- Joined
- Sep 9, 2016
- Posts
- 283
- Reaction score
- 109
Strange problem here.....
Wife complained that the engine has a hard time starting. I didn't believe her but I decided to "look at it when I can" which met with a frown (I tell her that her face is gonna get stuck like that someday and she'll look like those "Apple People Dolls" she made with my mom) :/
Here's what I found:
No CEL/SES.
All fluids ok.
Recent, 1 week old fuel filter, normal service interval with LOF
Drove it myself ... ^no abnormalities note by me until.........^
A week ago, it didn't want to start for me even though it always has - no throttle, just turn key and drive is SOP.
This time it truly flooded during a not-very cold morning (22F). FI engines DON'T FLOOD, and that's been a mantra for many years for me.
I actually had to WOT/Clear Flood Mode to get it started, and it limped on a couple of cylinders until they all cleared out and it ran smooth. again no CEL.
Fuel pressure is 60#Pre start boost, 53#running.
3,400 feet altitude BARO reporting correct for altitude.
Tip off fuel pressure jumps to 60 and drops slowly as RPM increases.... very normal.
CTS reporting correct cold overnight soak and no electrical drop outs during engine temp climbs to normal 195F... I assume CTS is OK too.
TPS smooth and normal at idle/closed and WOT
Injection PW fluctuates normally
Oxygen sensors all reporting nothing out of normal; crosscounts on S1 position good and lively.
Battery voltage normal, 0.001 VAC ripple from alternator = ok.
CC voltage above 11.7
While testing for the last few days it starts and runs fine. Again, no codes.
I know that the fuel pump idle pressure is right on the lowest limit, but the jump on Tip Off indicates to me that the pump is OK too.
The 53# fuel idle pressure is likely from our baseline altitude (3400 feet) here in Montana like I stated.
I have a new fuel pump for it, but just cannot see replacing one that tests out normal.
The woman is hinky on driving it right now but I think I need to have it act up more definitively before I start changing parts at this moment.
Any of you guys have any thoughts?
No CEL/SES.
All fluids ok.
