Working on a 2000 neon with about 88k miles. When in gear with the brake applied it wants to rev the motor and lunge forward.
Has new upper and lower motor mounts set at the right distance. New tps sensor. Only code shown is for upstream o2 sensor.
Also noticed the scanner shows timing jumps around from 6-9 degrees, which I'm assuming means the timing belt is due. I think those get changed about every 90k.
Got a couple of those molded rubber 90's which are dry rotted, gonna replace those too.
Any ideas?
Any ideas?
