Hey Everyone,
I have access to a 2000 Yukon XL parts truck and had a couple of questions about the rear end that I haven't been able to answer searching around. I have an '89 K5 that I'm slowly fixing up and eventually want to put rear discs on it. Would it be possible to pull off whatever necessary parts and brackets from the donor and just stick them on the K5's 10 bolt? Or would it be better to just pull the entire rear axle from the donor and relocate the spring perches and shock mounts and throw it under the K5? From what I've found online the newer axle (8.6" 10 bolt) should be about 1.5" wider and basically make the rear as wide as the stock front already is but I haven't seen anyone do this on a '73-'87 ('91) to confirm that. I know that it would be more or less a stock replacement (besides the discs) since they're both 10 bolts but I'm only planning on using 33" or maybe 35" tires and don't plan on wheeling it that much or that hard. Also, the newer axle has a G80 in it (according to the RPO in the glove box) and I was curious if GM started making them any better than the older ones that were known to have a high failure rate. What do you guys think?
Thanks,
Anthony
Thanks,
Anthony
