2000 silverado 14 bolt disc brake axle
Vombrown
Mountain Man
Great Falls mt
Does anyone have the WMS width on these? Disc brakes eight lugs what's not to like? I'm sure spring perches will need to be relocated but hey. You can't have everything.
Not sure off the top of my head but it matches the front and everything would have to be moved, what is nice is it's easy to adapt the emergency brake to the factory cables of our trucks.
I'm too lazy to take the tires off mine, but I measured outside rotor to the outside rotor and got 63.5 if that helps. From an 04 4wd. Yes, you will need to move the perches, and the shock hangers.
I think I can get it cheap. Like 100 bucks cheap I'm thinking the burb needs this. I will be adding a locker and prettying it up before I install it anyway so moving the perches and shock mounts isn't really a big deal.
Cool thanks guys. I wo t be able to go over and get this one until next week sometime so I didn't want to waste the time to drive out if it wouldn't work.
When I did mine it came out almost identical to the front d60. Doesn't have that tapered look in the back now.
