bp71k5
3/4 ton status
Fuel pressure is ~48psi. Starts up and runs fine if you step on the gas, idle just drops to 400rpm and then dies.
Any ideas?
Any ideas?
No cel.No CEL?
Hmm, looks like you might be right. Will try a regulator and filter first.96-up gm if i recall is mid to high 50psi range not 48 psi . so check that also for fuel pressure .
years ago we had a s-10 come in on the hook and it would fire and run but no power to move its self . turned out the fuel pressure was around 10psi below spec from a failing pump . installed new pump and like new truck .
not saying its your problem but better make sure .
Prob the pump
old vortec 350 is 60-65 psi
newer ls vortec is a bit less 48-53ish i found on line.
Of course, the mechanic can’t find anything wrong with it. Starts up every hour and idles just fine.![]()
idles and load are 2 different things to a fuel system .Of course, the mechanic can’t find anything wrong with it. Starts up every hour and idles just fine.![]()
