bigbadchev84
I am working on the wifes 2000 Tahoe, new body style, it has the 5.3 in it. I noticed it had been leaving tire marks in the driveway. She told me it has been steering funny too, I took it for a test drive and it steers like crap.
Ok forgive me if I sound like an idiot, not to familiar with ifs, try to stick to the straight axle stuff. It has a 6" lift and some 33s on it if that makes any difference.
I jacked up the front end, the tires turn without turning the front driveline. So I would assume that the 4wd is not stuck?
This thing turned on a dime before. A little background on what has changed: I replaced the passenger side outer tie rod, new idler and pitman arm, also put in new crossmember drop brackets for the torsion bars, and it has been aligned twice.
It just dosent turn worth a crap and feels like the front end is binding. I have checked with it jacked up and on the ground and it turns stop to stop, dosent feel like it when moving though.
Is there an easy fix here? Where do I go from here?
