On the passenger side there is some noise from the front wheel. I can here it when driving. When I hit the brakes the noise stops and when I turn sharp right the noise stops. I checked the brake pads and the pad is low but not yet at the squealer. About 30K miles ago I replaced the wheel bearing hub on this wheel with a made in USA Timken. I lifted the tire in the air. There is no play top to bottom. From left to right there is some play but maybe that is normal?
