What could be causing both of my rear disk brakes on a 2001 silverado to lockup? I replaced both rear the calipers and brake hoses. I lubed the slide pins and they moved freely.
To bleed the brake I had an assistant hold down the brake pedal. I then opened the bleeder valve to allow air to escape and then closed. Then the assistant released the brake. I bleed the brakes with tire off.
