2001 Silverado Z71 lifted and leather upgrade?
wazzabie
Washington State
1) Do you think this black Z71 is lifted? The rear has blocks.
2) These seats have side air bags. Would it be possible to swap side seat air bags in a 2001 silverado? I assume new sensors would need to be added and some other electrical work.
It looks like a levelling kit. Look at the torsion keys and see if they look newer than the rest of the chassis. Also I wouldn't bother trying to hook up a side airbag. Just bolt the seats in and go.
most 4x4 of that vintage got rear blocks .
check for maxed out adjuster bolts or newer torsion keys as said before.
DO NOT MESS WITH THE AIR BAG SYSTEM if you don't know what your doing. at work we had a truck come in from under 15 mph hit and took out both seat belt clips with auto tightening safty systems and also the 500or so doller brain was just under 1k when done with new parts and dealer only reflash of brain to truck .
hooking up more air bags if you don't know how the system works or if it can even be upgraded will not be fun .
not saying it cant be done .
and yes looks like small lift/level kit in the truck .
