2002 Silverado shocks on an '86 K5...will it work?
jonrpick
3/4 ton status
Marietta, GA
Ok, I know I should just get new shocks, and they're not that much, but I'm in a financial bind.
I just helped a friend swap the front and rear shocks on his 2002 Silverado 1500 today. I got the old rear shocks. They *look* like they'll work. The eyelets at the end fit my rear axle ok.
I don't have a length for my old ones though, because they were thrown out.
This is strictly a temporary solution. Truth is, 6-year old shocks are going to be better than the 22-year old ones that came off of it. I do plan on getting the right shocks soon, but right now I need something that'll get it down the road ok.
I looked up the rear shocks for both trucks on Advance Auto's website. The part #'s are very close, but not the exact same among the same model shock for both trucks.
So will this work as a temporary solution until I can get new ones?
Edit: a couple of my friends think it should work as a quick-fix... although the valving may be different.
Edit #2: both trucks are stock height, his is 2WD...
biggest thing id worry about is overall length and compression. Most shocks for similar body style trucks are the same...IE; a reg cab short bed 2wd 1500 silverado and a 1500 2wd suburban may use the EXACT same shock. Valving could be a little weak, but its better than no shocks.
That's my thinking. If they bolt up without needing compression or stretching, the length should be A-OK.
And again, 6yr old used shocks are better than 22yr old used shocks.
yeah, as long as they are "near" the center of the stroke, they should be fine. we replaced the shocks on my dads 00 silvy a little over a year ago...his stockers were actually still decent with like 120K on them.
By the time I'm actually buttoning everything up, things may change, and I may be able to drop some coin on the "right" ones, but I think these will work for a month or two. Won't know until I can get the axle back under the truck.
