2003 1500LT Burb, and questions!
utherjorge
Pennsylvania
I think I've found my rig I'll stick with.
It's a (currently) stock 2003 Suburban and I'd like to replace the shocks. It is at 100k and I don't think they have been swapped yet.
I was thinking the 5100 Bilsteins. But I wanted to level the truck out so the front is the same height.
I see a Rough Country kit, but the Blazer I had rode rough with those. Are there any kits to level it out that any of you are aware of?
Bilsteins are a great shock, you'll be very happy with them. If it has Autoride then you'll need to install resistors on the shock connectors to keep everything happy.
Their are few companies that make new torsion bar keys to lift the front. You may be able to tighten the torsion bar adjusting bolts if they aren't already maxed out and not have to buy the keys.
I went looking for a burb without autoride for that reason. I won't have to play around with that mod, which scared me when I read about it.
I have to call the Helliweg (sp?) people to see if I can do keys and their bars, but that's where I would like to be eventually.
