My father has a 03 Chevy Silverado 2500hd 4x4 and I'm pretty sure the t case is on it's way out . My question is , what case is it? The truck has the pushbutton 4x4 system ( 2 high , 4 high, neutral and 4 low), it is a automatic trans, not an allison so I am assuming it's a 4L80?
I found a used case for a decent price from what sounds to be the same truck, but I am not sure how many different t cases or versions GM used in that era?
thanks in advance - Josh
I checked into the known problems with the dash switch and the enoder motor sensor and unfortunately the horrible grinding/ scraping / ready to explode noises it's making are internal.
6.0l engine and it is a 4L80E trans.
