michael0584
I bought a 2003 suburban about 3 months ago with 155,000 miles on it. Everything has been fine on it till today on the way to work. It now has 160,000 miles on it. I noticed it seemed to be shifting a little later and when i got on the freeway it shifted to overdrive then starting dropping in and out of overdrive to 3rd. If I put the shifter in 3rd it stays in 3rd just fine. Its definitely dropping into 3rd and not the torque converter lockup. The rpm change is about 800rpms and when it drops out and I manually shift to 3rd there is no rpm change. At one point it was staying in OD and i pushed down the gas to see if it would downshift and the rpms shot up about 2000rpms, and speed did not seem to increase. Definitely felt like it was slipping and not a downshift. I did pull off the freeway and check the fluid level, it was in the hash marks and still looks pink. Maybe slightly burnt but not bad. I then killed the engine and cranked it back up and got on the freeway and it acted the same way. No service records on it but the drain plug looks like it has been removed before, so assuming it has at least had a partial fluid change at some point. Hoping this is fixable and not a complete rebuild. Any help is greatly appreciated.
glad it worked itself out, hope it stays that way a long time
