I've got a 2003 GMC w/ the Duramax/Allison in it. Ran fine yesterday but this morning I fired it up to go get some breakfast and on my way to the store I notice my gear indicator isn't working. I move the truck into neutral and back to drive at a stop light and then my brake and ABS lite come on and the dash reads "SERVICE BRAKE SYSTEM". BTW, the brakes work fine.
Then I notice that my truck won't shift and the speedo quit working.
When I shift from Park or Neutral to Reverse or Drive the tranny slams hard into gear.
The truck runs and stops fine otherwise. All the fuses in under the hood check out fine.
There are no trouble codes on the OBDII computer. The only lights on are my brake and ABS.
I changed my speed sensor and ignition switch today and neither helped. Some of the other forums talk about changing the neutral safety.
What do you all think?
Thanks,
Rick
Thanks,
Rick
