2003 Honda Pilot help needed
cbbr
1 ton status
High velocity, Low altitude
It won't start. It started fine, but now it just turns over. I checked the fuel pump fuse, its good. Anything else that you guys know of that is a common failure?
they are a very common problem with the honda's in cold weather.
might take up to 30-45 minutes then they fire right up, and can be a "here now, gone in an hour problem"
Good luck!
