I have a 2003 Silverado w/IFS front diff. I have terrible leaks from the seals.
I was under the impression I needed to remove the diff to replace the seals (thinking semi-floating remove an internal pin type event) but after some research I think I need to leave the axle housing in the truck, remove the 1/2 shafts, beat the left side with a BFH, unbolt the right housing extension, BFH and whalla pop the axles out. Replace the seals and possibly the bearings and reassemble.
Anyone know for sure?
. Carson City.
