Cipher
Registered Member
I recently swap out my 4.3l Vortec to a LS III, 6.0. However, I left the old 4l60E in it since it was pretty much brand new. I did the pinout for the 4l80E harness to the 4l60E that I found here:
. However, I have encountered a few issues that I will share.
- Swapped the flywheel from the 4.3 to a 5.3 to match up
- Had to remove the spacer from the flex plate to align the starter to the flywheel.
- Reflashed ECM to accommodate the 6 cyl to 8 cyl swap along with Stage 1 CAM and cold air intake.
- Removed the CATS
- Installed long tube headers.
- After the swap I had to replace the shifter cable to the 131" (only used the rear cable portion) but
