Hey guys...
I'm trying to get the Yukon (5.3L / 2WD) started... The ex wife was out in it and it wouldn't crank the other night. She happened to be in front of an Auto Zone. The dude there looked underneath, and while she tried starting it there was smoke coming out of the starter. So she picked up a new one.
Fast-forward to today... I just swapped the starter out (with no jack or any way to safely lift the truck, mind you). It now cranks/turns over, which is an improvement, but the only gauge that moves on the dash is the tach. I don't hear the fuel pump whine when I move the key to the run position. If I leave the key in the run position, the fuel gauge doesn't move, and the check engine light stays on, although I think the CEL being illuminated in a non-running car is normal, no?
I've seen some mention of the starter failing and causing other problems further upstream. Right now the truck is parked in the street on a cul-de-sac and needs to be moved ASAP (nosy HOA neighbor-types *will* complain).
Where do I look?
Thanks, Y'all!
~jp
Where do I look?
Thanks, Y'all!
~jp
