F-ingrob
Wheres the mud
Is anyone know what the factory Paul’s signal is its a 2004 LS
Is it 128K
Is it 128K
The factory tune is looking for 40 pulses per revolution sensor. It takes that and mixes it with whatever gear ratio/tire size is programed into the tune and outputs 4000 pules per mile to the speedometer. If your running a Electronic trans with pre transfer case VSS signals you will need to have the low range switch hooked up so it knows to change the shift parameters for the different speed output. If your VSS is located on the output of the transmission its less importantSorry VSS
