The problem here is there's some sentimental attachment to your 'sub. The real answer (and it's been discussed many times on forums and articles in magazines) is it makes absolutely no sense, time wise or financially to convert a particular vehicle to 4wd if that vehicle was produced as a 4wd. You'd be leaps and bounds ahead to just sell your 2wd and buy a 4wd 'sub....
BUT, like I said you've got some sentimental attachment to this one.
Think about sourcing the front crossmember/subframe assembly, 3rd member, CV shafts, probably different unit bearings, maybe even different knuckles, front d-shaft, transfer case and associated wiring if electric (or linkage/cutting a hole in the floor if it's manual shift), t-case crossmember, shortening the rear d-shaft, etc.
It can add up fast.
If you're attached to this vehicle I'd run it as is and get her a 4wd something to run around in during the winter (assuming that's why you want 4wd).
