CA 2004 TRX450R
K85 Octane
People Fatigued
San Bernardino CA
2004 TRX450r
Bought new myself, 1 owner
Engine
CP 12.25 standard bore (not an “off the shelf piston”)
P&P head
Hot Cams stage 2
1 ride on the following*
*Larger valves and valve job
*Valve Springs, retainers, keepers
*Valve guides and seals
*Cam Chain and all gaskets
*Rossier Full Exhaust
*UNI Filter
Jetted carb with plenty of extra jets
ESR temp gauge
Cylinder was changed out maybe 3 times over its life. Jugs and rings are cheap to replace every few years when it’s standard bore. Low hours on this jug.
Suspension and Frame
+2 A-arms on revalved/ resprung front shocks
Denton steering stabilizer
Houser extended stem with isolators
Protaper Fatbar handlebars
Houser extended swingarm
SS swingarm bolt
Elka Elite LT shock and linkage
RPM axle carrier
Dominator II lifetime warranty axle
AC nerfs
Full Skid plates
Original plastics and seat in perfect condition
Tires
Champion Beadlocks and Red label Douglas rims
SandStar, GBC, Holeshots, Razers
Tons of extras
Extra wide aluminum ramp
Fluids
Carrier bearings
Bottom end gaskets and bearings
Cover
Whatever else I can find at the time of sale
Has good gas in it. Come test ride. Was ridden at Pismo June 2nd, no issues. Asking $7,000 $4,600. Have well over double that invested but I know that doesn’t mater. Will update if I think of something more.
Could bring to BB. Couple pictures from maintenance before the Pismo trip.
  • IMG_7523.MOV
    64.8 MB
