runamok151
1 ton status
Time to sell the Dodge. It's an '05 Ram 2500 SLT, Quad cab, short bed, 5.9 HO Cummins, 4x4, automatic. 179k miles. Factory bed liner w/ aluminum diamond plate bed rails. Dealer installed tow hooks and block heater. I've owned this for the past 13 years and have complete records. Over the past 15 months routine maintenance has included ball joints and rod ends, 305/70-17 Cooper AT3s (dealer re-calibrated speedo), brake calipers and pads, fr. drive shaft, and just flushed all fluids.
I had the bed sides painted when I first bought it due to a couple scratches from gravel and some of that gel coat is now coming off (thank you birds). Also has a little of the typical rust around the rear wheel wells, which I treated w/ permatex before putting on the fender flares. No lift and never tuned. Aside from the deleted cat and K&N filter, the truck is completely stock. Cobra CB stays. I've only used it to tow a few times and can't justify driving it any more.
$16,500
$16,500
