2006 3500 leaf spring question
K85 Octane
People Fatigued
San Bernardino CA
Looking to change the rear leaf springs in my fathers 2006 3500 GMC. I would like to throw some 1500 leafs in, just to smooth things out. We are no longer hauling an 11'3" camper, only trailers. The truck still has airbags. :bow: It is sooooo rough around the freeways of Los Angeles. Choppy doesn't come close :doah:
the 64" rears just got a extra leaf basicly in the packs as thay went up in gvw specs. so prob cheeper to just pull a leaf or 2 depd on the # of leafs in the pack now.
well, I can get a pair of leafs for a cheap price right now, off CL. Are the bushing sizes etc the same from 1/2-1 ton?
Why when you can just do what was suggested and pull a leaf or two?
My dodge has a really light rear spring pack (like 3 leaves) and I have bags. I really like the setup (especially with the extra weight from the service bed) because it rides great unloaded but with the bags aired up I can haul whatever I want without any issues.
hmmm which leafs should I remove? I pulled some leaves from my suburban 56s, but they started out with 7 leaves, now 5. I think my fathers 3500 only has 5 or 6 leaves, so pulling even one leaf seems aggressive. I'm glad to hear big trucks can still run good with only 3 leaves.
I guess my hesitation stems from all the talk about removing leaves and damaging packs. Not to mention it's not my truck, just trying to give him a smoother ride. With my blazer, I couldn't care less, just go to a junkyard and pull some more.
top leafs are dd use range. farther down the pack is the load range leafs.
as to less leafs over older style its easy . leafs are thicker comp to older stuff.
and the 64" springs ride better than the older stuff anyday .
