2006 silverado 2500hd with solid axle front
supersize75k5
OrganDonorRacing.com
gilbert az
Sadly with the work truck, buggy and my other offroad truck I am not having much use for this anymore and would like to sell it before I kill the body.
2006 2500hd ext cab long bed LS with a solid axle
attachment.php
Pics of the truck on 37's
attachment.php
attachment.php
and a picture to compare the hight to a stock duramax for reference
attachment.php
6.0 with 196k
new 4l80e with 2500ish miles, shift kit and a boost valve iirc
converted from a push button 263 to a 241 with factory floor shift
14 bolt rear with a factory gov lock and 4.88 gears, new fluid
2 piece rear shaft, ford superduty 1350 cv front shaft with 1310 at the axle iirc "i may have went to 1350"
-78 hd ford hp 44 with new 4.88's welded, new bearings, races, seals and rotors, new warn hubs and 3/8" cover
-tapped knuckle, ARP studs, WFO concepts raised steering arm, track bar with 3/4" hiems
-draglink and track bar are on the same angle
-stock rear 52" springs up front with new bushings, rancho 9000xl adjustable shocks
-4 inch lift leafs out back, braided lines
-new hd fan clutch, power steering pump, radiator, hoses, wires, plugs and battery
-front recovery points and I left room for a winch behind the skid/bumper
-big toolbox and 10lb abc fire ext
-can come with white painted flares or the black ones
-pwr doors, windows and drivers seat
Does not come with bead locks, or the lightforce lights, will come with polished hd wheels and I am currently shopping for a good set of tires and will have hella lights on the push bar. This is somewhat negotiable but I would like to keep the beadlocks, but I will include the light forces in the full price option.
What it needs..
-T-case front output seal leaks
-new ebrake cable needed
-dent on driver rear door and cab, I have a white replacement door to go with it
-passenger window rolls up slow
-exhaust has a leak
-small dent on passenger bed and I think the rear door.
-rear bumper is pushed in on the corner
-carpet needs cleaned
-drivers mirror lens is broken
-grill is missing white outer beauty pieces
-windshield has scratches, no cracks or chips but plenty of scratches
For full price I'd have the dents fixed, t-case resealed, and appointment with the exhaust shop, detailed, new glass, grill, window regulator ect.
Its a solid truck that rides nice and smooth. Just went to moab and back even at 70mph or..100mph :flipoff: I think it needs a winch, sliders, locker and chromo shafts up front or a dana 60 for it to be just right.
8500 as is, 11,000 with the bad list fixed or somewhere in between depending on what you want done.
Possible trades would be towards a 2007 white new body style 5.3 single cab long bed or I can add cash towards a white single cab LMM "08 body style" Duramax.
-Shawn
480-228-3218
Wrong side of the country, if you was closer id offer ya my 00 GMC 4x4 long bed regular cab 5.3 auto and some cash.
If yours was a new body style 07 Id drive across the country, any exscuse for a road trip:D
I need a new body style being it will be used for work, I want to get a wrap or vehicle graphics done on my next work truck and want it to look fresh for a while.
Thanks though!
