Its been a couple months.... Im jonesing for an update.
Yeah it has been a while... I have put about 5,000 miles on it and done some mild towing with that too.
Did some driveway clearing with the truck in Dec:
I've ditched the oil can for the moment, I checked to see if the PCV port was plugged, it is not plugged - I need to route the catch can setup differently. Instead of mimicking the 6L setup I need to utilize the port on the front of the intake manifold that leads right to the crankcase - there is a 1/4" NPT plug for where the oil drain is for the medium duty accy drive setup for the versions equipped with a belt driven air compressor. Also this requires me to plug the port at the bottom of the intake manifold but if I do that I need to remove the intake manifold off the truck and while im there I will "have to" chop off the plate and let the intake manifold breathe a bit better. Common modification - but Raylar wants 1000 to do this however I got expert aluminum tig welders locally who are good friends - so should not be a big issue and can be done for beer money. So right now its just running the traditional PCV setup that is stock with the 8.1
After that I had a minor fuel leak at the rail which was a minor fiasco in the sense of getting correct parts of facebook groups (whole nother issue of stupidness...) - no fire but the o-ring failed at the crossover tube that goes from the driver side fuel rail to the passenger side rail causing it to weep fuel, very noticeable when you get out of the truck and go to walk towards the front of it, so I took it apart and had a friend weld some AN fittings on both sides and connected it with a stainless braided hose - now it cannot leak and cause fires which is a plus.
I wasn't going to attempt another pan job so I had a local shop fix the oil pan leak and fixed it with my purse, meanwhile I had them run a leakdown and cyl comp test but I don't think they did it right, they showed 135-145psi across the cylinders with 15-25% leakage. This thing should run like ass imagine but it runs really nice, except it seems to have a slight miss at idle. The oil pan leak is fixed but the CKP leak is still constant and I cannot get it to stop leaking for the life of me - quite frustrating.
I had a total of 4 or 5 lean misfires that registered codes for high load/rpmwhich makes me worried, I'm going to perform another comp test next week when I have some free time (work has been very busy recently) but here was my recent oil analysis sample:
the column on the far right was when I originally got the engine and pulled as much oil as I could from the oil filter, the grey column is the average of the 2 tests Ive done
I was ready to do another engine tune but I will wait and see how my comp test goes not to mention recently the TQCV is making some noise when stationary for a while, (2-3 or more minutes) I get a grumble like a bag of stones...when you give it some revs It seems to drive okay and go away with more revs/load but is only happening when in gear, (not P or N) but I checked the flexplate to tq converter bolts and they are tight as can be however its quite worrisome because the noise is getting worse. I wonder if the pump is failing in the TQCV...
I have a trans cooler line leaking that I need to replace, its not bad leak by any means but any leak isn't ideal so I will take care of that and possibly do a pan drop and filter job to see if that helps the noise. Other than that I dunno if I am down to a custom tqcv route again...
not out of the woods yet!
