While fixing the rusted frame I decided to fix the transfer case leak. Got it out and found a disaster/mystery.
Fluid is basically black. The drain plug has a solid coating of metal (no pieces, all fine dust). Opened the fill plug and zero came out... Dry as a bone.
Dropped case and found a snap ring sitting inside the transmission/Xfer case adapter. Snap ring was fractured in 5 or six pieces. The ears were both broken off and other pieces were in the Fluid. The input seal was simply sitting there. IT WAS NOT in the bore where it should be. I looked inside the bore and could see the bearing but there was NO GROOVE for a snap ring. What's going on here. I don't see any place for a snap ring.
Ideas? Thoughts?
Ideas? Thoughts?
