Ok so i have a 78 np205 and a sm465. i have problems with being such a short front driveshaft. so ive been thinking of adding the np203 to the setup. what all is required to make this work. (i might even have a np203 lyin around down at the shop) also wana clock the np205 so that it is even with the frame rails at the same time. what adapters did you use? how well do you like it? need something to play with over winter no real hurry, just need some info.
