I have some days off and figured this is the time to tackle this. If I can get motivated.
I have ORD competition motor mounts I want to install as well.
So, I suppose the course of action is.
First chalk vehicle, then.
1. Remove drive lines
2. Drain and remove 203
3. Support transmission
4. Motor mounts one side at a time
5. Remove exhaust to remove the transfer case drop.
6. Install 205, hopefully torque bar fits as well.
7. Measure for new or reworked drivelines
8. Drive with open headers to exhaust shop
With the motor mounts, I do have an engine hoist. Can this be used to do the motor mounts even with 4" lift and 35's?
Since I refurbished the 205, I can assume it's working as it should since it rotates as I turn it? And with the shifter installed it shifts as well.
Any advice is welcomed. That 203 is a beast and I think I'll open the doors and use the engine hoist if I can to remove it. I used a transmission jack last time and it wasn't too bad but a bit sketchy. Not sure how to support the 203 with hoist through the tranny tunnel
I don't think I ever tried to pick one up.
