203/205 triple stick 1 tons shafts
mudboggink5
NEW JERSEY
Had it posted hole but decided to keep only the motor/seats/wheels and tires
You get
No engine but complete tbi computer and wiring fuel pump and fuel cell
Sm465 Trans newer clutch 203/205 doubler case Offroad desighn triple stick dana 60 front 513 gears Detroit locker 35 spline outer shafts poly performance drive slugs glo diff cover balistic steering arms
Cross over steering hydro assist
14 bolt rear 513 Detroit disc brakes ruff stuff diff cover traction bar
New shafts 1350 u joints
Aluminum dash 12v guy switch panel
Cage with seat tied in fuel cell cnc brake cutter
Rear of body is dove tailed
Clean frame no cracks no rust on body
Front has 56 inch springs with extended shackles rear has shackle flip with 63inch springs bilsteins all around
Want to sell as a roller $4500
Call or text 973-600-1798
Located in southplainfield nj 07080
