I have a 71 jimmy that came with a 205 and a TH 350. The adapter plate has cracked and I have an extra 203. will it bolt right up with the cross member? Just want to put it in till I can find the adapter?
you'll need the adapter for the 203 but it should bolt up just fine if the spline count is the same although I'd find a new 205 adapter and keep it, might as well twin stick it while it's out
So I pulled out the 205 and the 203 is much longer than the 205. It seems as if I am going to have to shorten the drive line for it to work. I really want the 205 in and if mods need to be made I would rather it be done with the 205. Any input would be nice.
