203 32pline input seal
CrewCab59
Knoxville ,TN
Trying to find the 203 32 spline input shaft seal , all the seals I have found are to small for the retainer?
Well I have talked to many different shops and ord and he didn't even know what seal it have , All the seal that could have / should have is too small.
Still looking or I will machine the retainer for the next larger size.
Here is the list that i was given
3173
19255
19267
19264
19387
I looked around for anything I might have forgot to package up when I sent the doubler...sorry but I've got nothing.
The bigger question I've got is why is ORD sending out doubler kits without the appropriate seal? I bought everything from them ... 32spl input/seal kit/adapter.
I've heard of few people missing this seal from there kit ...
Jeff,
Thanks for looking .
What bearing retainer do you have? Who did you talk to here at ORD?
Worst case, you can measure the OD and ID of the seal you need and any decent parts store (NAPA, Carquest, etc) can get you what you need.
We do tons of these things and I don't remember your call. I can't imagine we gave you the wrong part number for the stock seal but who knows. Feel free to give us a call on Monday if you don't get it figured out by then.
The retainer was on the Np203 which had no seal when I bought it,the doubler was New/ used and was bought from Jeff.
When I called he was in a rush to get off the phone becasue he had another guy calling in " Mexico " . The seal was a good number but just like the other 6 different seals .008 to small.
No blame to anyone but I find it hard to believe that a seal can't be found for the retainer.
I also called " Motion Ind " which they deal with bearings and seals couldn't even help on the seal because of the OD.
It's all fixed with a different retainer !
Thanks to all that helped.
