203 cross member differ from 205 cross member
down4thakrown
flagstaff,az
what it says^ /forums/images/graemlins/1zhelp.gif /forums/images/graemlins/thinking.gif
I'm not so sure. I have 2 '73 K5's, one I used for parts for my project, the other one....anyhow, in tearing down both trucks the crossmembers were different.
One was TH350/NP203 and other SM465/NP205. The memebers were in the same location fore-aft, but the mounting holes on them were drastically different. The NP205 version also has a side bracket that bolts to the frame rail and helps control torque under power
I think there were a few different ones but it should be easy to find one to fit. I've never had a truck older than the 76 I have now and it's using a crossmemeber from an sm465/np205 combo on a th350/np205 now. All the other crossmembers I have laying around have the same holes. I've never seen one with the NP205 brace but I've heard of it.
Andy
Yes..they'e different...
they are almost alike...
The 205 is closer to the crossmember...
so the area by the front output is more countersunk..
then the 203...to make room for the driveshaft flange..
You can use a 205 crossmember on a 203...
But the 203 crossmember will hit the front shaft...when running a 205...
With the th350/205 combo...
80' is the most common..
what about a 208 cross member?
would i be able to use that? /forums/images/graemlins/confused.gif
No...the 208 is different..
You could probably modify the 203 crossmember...
Do you have a torch and a BFH!!!
