203 full-time axle hub removal
deeds86
Registered Member
Waseca mn
I'm trying to prepare myself for front axle joint replacement, Ive been watching some videos online but none are for the full-time 203 tcase front hubs as I don't have the part-time kit installed... Does anyone have pics a diagram or even a good write up? Nothing showed up with the search feature
full time drive slugs are easy, you just need snap ring pliers. Is a solid metal slug spline'd to axle and the inner hub. IMG_20210705_125002.jpg
That's what it should look like. There will be a cup shaped washer for the spring to sit in toward the bearings.
After the slug is out, is the same as an axle with locking hubs. This is the socket for the spindle nuts.
And Welcome to CK5 @deeds86
