I belive it has a part time kit, but I didn't install it. I can have it in 2H with the hubs unlocked & if I drive forward the front driveshaft does not turn. I don't know if that means it has a kit for sure, but I think so. The noise is coming from the T case, you can feel the "skipping" in the T case shifter handle, + you have to hold it forward with a good amount of pressure to keep it in 4L otherwise it pops out on the first "skip". It still goes in what amounts to 2L, the rear wheels still drive, just no front.
I wish I was set up to make a video & post it on youtube! That would be easier than trying to type it out!
I really don't think it's the frontend, but I have been wrong before. The noise is coming from the middle area under the truck, then I bent down to listen/look & it is definetly sounding like its the T case.
So, if it is the chain do you guys have any advice on a good replacement? I guess I could just get a used one from the Junkyard, but I'd probly be right back here before too long.
Well, I hope I can figure this out!
Thanks- John
edit: do you guys think the shifter adjustments could be far off enough to cause these types of problems?
