I don't have a K5 but you guys sound like you can help me. It is a 79 chevy LB PU TH350 with a 203 TC that will not go into 4X4. I do not know all the history of this truck but it has manual hubs and I assume the part time conversion kit because it will pull with the hubs unlocked. The TC will shift into low range and pull but when shift to LOW LOC it jumps out. Both high and high loc work but the front axle never pulls. I check the hubs by jacking the front off the ground , locking the hubs and the front drive shaft turns when the wheels are turned. Where do I start, with the conversion kit, linkage or somewhere else. I would like to have an idea where to start with out just taking things apart and guessing. It is a beater, I drive it less than 500 mi a year but I would like the 4x4 when I need it. THANKS
