203 to 241 adapter?
BUDDY
Midland, TX
I posted this in the garage here, but thought this would be a good place to ask as well.
I have in my parts pile -
NP203 range box
fitz all spacer/adapter
700r4 transmission (to be rebuilt)
I was going to put all of this in my 72 blazer in front of the np205 that it came with, with some form of doubler adapter, (NWF, ORD, etc.).
But, I bought a 1990 blazer, so i got to thinking. Could I put the 203 range box & adapter/spacer in front of the 241 t-case that resides in my new to me blazer?
My impression is that this would be a feasible swap, but I'm not familiar enough with the configuration of the OE adapter between the 700r4 & the 241. Spline-wise it should all be the same 27 splines throughout, but the bolt pattern is my big question.
Anybody know the answer?
Just thought of this (at work), & my truck is parked at home or I'd just climb underneath it to find out for myself.
Thanks,
Buddy
I think all of this is not really valid since doubling the torque to the 241 will make it want to explode on a regular basis.
I would stick with the conventional thinking of a doubler.
Not to bash your idea but I foresee many problems strength wise with your proposed setup.
The 241s are strong cases, they just don't like smacking into rocks. People put doublers in front of them all the time. The only thing I don't like is the slip yoke rear, but that's fixable (just a little more $).
Don't know about using a 203 range box, but there are better options out there. How about another 2.73:1 low range gear in front of the 241? That 7.45:1 low gear puts any 203/205 gearing to shame. I think it's the "Box for rocks" or "box 4 rocks" adapter... and it looks very affordable compared to other doubler kits...
If you just want to use the 203 because you have it, I can understand that. I have heard you can redrill the face of the 203 for the 6 bolt round pattern, and it will bolt onto the 700r4/208 (or 241) adapter. I am doing this in my toyota... but I'm not sure what adapter would be out there to mate the 203 to the 241. ?
