broncoman6524
on the truck im building its got a 205 witht the front yoke that holds the actual u-joint, the 203 that came out of the parts truck takes the Circlular design.
the stock shaft no-longer fits, and i have an extended front driveshaft BUT it mounts via the circular yoke. is it possible to swap them over? and if it is do i need to take caution and buy a new nut like i would do when replacing a pinion seal?
thanks guys
chris
thanks guys
chris
