reddog64
So before i put my 205 transfer case on I swapped out the rear shaft to a 32 spline shaft, mainly to eliminate the slip yoke.
I called up HAD and ordered the stuff i needed.
The new shaft, big internal gear, the speedo housing, and the CV mount (HAD Specialty)
So after swapping all my needle bearings over and putting it all back together with the new/used parts.... The HAD flange wont go on all the way...
On the end of the shaft, there is a little "C" ring that holds stuff in place... It slides over the shaft and clips into a valley on the shaft.
Problem is, when i put the HAd shaft on, it hits the "C" clip.. and wont tighten up without breakign this clip...
If i remove that clip.. it would tighten up against the bearing in the speedo housing..
Also i guess i need some sort of gasket/seal to seal around the flange/housing... right now it's open right to the bearing...
I'm gonna call Jesse on Tuesday and see what he says, but am curious if anyone else has done this...
here's the flange
http://www.highangledriveline.com/1350cv.html
little better picture
here's the flange
