4x4_76
Regular married t-case converted to divorced. Absolutely no modifications done to t-case, or parts. Accepts 1410 cardan with DN120 bolt flange.
I used original 27-spline drivesleeve, which I cut in half. Then I welded the flange to it, and turned the final shape to it. Parts were pre-heated before welding to make welds as strong as possible.
Inside the housing is slide bearing and shim, and the flange is held in place with bearing nut.
If someone wonders why, answer is simple: divorced cases are rare in here, and I already had a good t-case, so why not
