So I've got a 205 laying around whose front output can be significantly moved/shaken/whatever by simply grabbing hold of the flange and lifting up/down/side/side. what's wrong and what's it take to fix it?
you can grab hold of it and give it a good shake. it's way more movement than the one that's in my truck.
can just the one bearing be replaced? how do you go about getting the bearing - is it something a typical parts store will carry?
