205 in a 98
possible with ford 205 case and some swaped around parts to mate it up. then jump up to the garage section and search for 205 speedo and vss stuff. its not that hard to make one vss output rather than cable.
Only issue I see is if GM changed to something other than the 40 tooth reluctor by '98, or if it's the same as used on the 1991 GM 205. If same reluctor, then should be a drop-in, and as mentioned, there is a post about how to make the 205 VSS output housing.
