I'm interested, do you take paypal? I'm going to have to check my winch out again and see if the input is on the driver's side or if it isn't maybe I could use it out back and swap the drive in the PTO. BTW, I'm in Decatur TX.
***edit, just remembered you were looking for a tranny PTO (? or just a tranny?) and I have one off a GM SM465 that is set up with the output at the back and a shift lever. It's a sweet unit with reverse and I think you could swap things around inside to have the yoke at the front if needed. Swap you straight across if interested, it was running this 12,000Lb. Ramsey industrial winch I have (more like 20,000 with 1/2" cable).
