205 Pto
broc944
Northern Minnesota
I have a 205 that has a PTO. Exactly how do you control the PTO function? If anyone has an exploded parts view of the PTO I would greatly appreciate a copy.
the PTO should have an input that you can make cable or linkage driven. then a lever wherever you want it. you should be able to find PTO cables on the net real easy.
see if there is any info on the PTO unit then do a search for it online. should be able to find the specs of the PTO and if you can find a maker thats the place to find a cable or linkage setup.
The PTO would only work if the transmisison was in gear on this application right. I know if it was on the trans it would work even in neutral. Not sure about how this is driven though?
