205 Rear output yoke
pseudomike
MA
It's either 1310 or 1330. OEM, sandblasted and painted. Great shape! $25 plus the ride.
I also have a complete 205 (slip yoke style) rear output. It was one of my first attempts at the VSS conversion. I think it needs bearings but the electronic speedo still worked fine. I never found a suitable plug for the original speedometer drive so I siliconed a rubber stopper in there. Not the prettiest install but it works and what do you want for $50 plus the ride.
Chevy never used a 1330 joint only Ford. Post the cap diameter and width and I can tell you what u-joint it is.
I think it is 1330. I will get some dimensions. I don't know if the ouput is a ford, dodge, or chevy. I bought it reman to replace the slip yoke above and it came with a yoke pre-installed. I replaced it with a Northwest Fab 1410 yoke. It's 32 spline, that is for sure, other than that?
