205 seal replacement
mctrigger
Registered Member
alberta
good afternoon folks! the other day i was looking around on the belly of my blazer when i noticed there were some leaks comming from my 205 t case on further inspection it seems to be comming from where the two shift linkage rods go into the case. i have looked on the net for some time but i havent found any info on what type of seals they are. has any one changed these and if so can you tell me if i can remove and replace without having to dissasemble? i have to remove the t case to changed my cracked adaptor so it will be on a bench. thanks for the help.
i think you got the wrong link to the pic. what do i gain from a twin shift? seems like a pain to deal with
:doah: my bad sorry.
all fixed now and tested.
as to twin stick = independint control of front and rear drive.
ie: rear high-n-low by its self .
ie: front high=n-low by its self.
but safty is still there to not let you mix ranges ie : high and low together.
