205 shift rail positions
muddermilitia
ThatTrazerGuy
NE Illinois
I need to know what the shift positions are for a twin sticked 205. Levers forward or back doesn't help because of different linkage styles, I need to know the gear regarding actual rail positions (in/out).
Thank you that does help
rails in= low range
rails out= high range
rails mid=neutral
Now to go blast through some snow!
the 205 is setup w/ 2 rails, both rails operate hi range and low range. Each rail is specific to the rear output or the front output. Rail pulled out is High range then neutral then rail all the way in is low range. Works for both rails. If you want to disengage an axle, you simply put the lever in neutral and the other lever stays in gear.
